check engine / o2 sensor trouble
2004 civic ex 73000 miles check engine light came on. had codes checked out at autozone. po134, po171, p2a00. Ox sensor circuit bank 1 lean blah blah blah. I replaced upstream o2 sensor and light went off. drove car 10 miles to get gas and light came on again. reset by disconnecting battery and turning ignition key to on. drove car 30 miles and light came on again. what should I be looking for now??? gas mileage is less than expected.
Next thing to do would be pull codes again. Whenever there is more than one code you want to see which ones may be old, and which ones will reoccur. P0171 and P0134 are probably both due to a general lean condition-- maybe low fuel pressure, clogged fuel injector, problem with MAF sensor, or leak in the exhaust manifold fooling the sensor.
Is the car modified in any way, or is it stock? Also does it generally run OK, except for CEL on and low gas mileage?
replaced map sensor had the check engine light reset and after about 4-5 key cycles the light is back on with single code PO171. dont seem to have any vac leaks or noticable exaust leaks. gas mileage still sucks. what should i be looking for??? fuel pressure problem???
CatsnotCars
Jan 28, 2015 12:24 PM
nemethjames1
Mar 31, 2010 02:11 PM
Vox1
Oct 14, 2007 12:29 PM
supapoopa
Nov 14, 2005 04:57 PM
aarona1000rr
Aug 10, 2005 02:42 PM
