Civic Coolant hose
Ok guys, so I did a swap in my civic b/c my motor blew. I used a 95 dx block with a 96 Vtec head. I put everything together, but there is a skinny hose coming from the back block next to the lower radiator hose. I am not sure where that hose goes. I took it to one of those commercial car shops and asked them to check the hose placement for me and they said everything looks good after 5 minutes and that hose is just a breather hose. I don't think so since it is coming out of the water pipe and shooting coolant all over the engine when i give it gas causing the car to overheat quickly. Does anyone know where this hose goes?
Some of the parts on the intake manifold have coolant flowing through them. Hoses about the size of fuel lines are used to connect them up.
If that's all hooked up and you still have an extra port you can just plug it up.
Yes I have the same thing running a '95 engine in my '91 with the old DPFI manifold. I put a short piece of hose on that port and plugged up the end of the hose with a bolt (use a longer bolt that is not threaded all the way to the head, and clamp on the smooth section). It has held up OK but a less "rigged" way would be to use a brass barbed hose to pipe adapter and a pipe plug. Or pinch the port shut and weld it, or swap the whole pipe on the back of the engine between the thermostat and the water pump with the one from your old engine. I think it will fit but would've been a lot easier to do with the engine out of the car.
voxleo
Jul 20, 2012 05:26 PM
voxleo
Jul 19, 2012 11:55 PM
TrucifiX
Sep 2, 2011 05:10 PM
