Civic hessitatin under load
Old Mar 2, 2010 | 09:12 PM
  #21
S142JZKillaV10's Avatar
Yes I def got spark Dame thing shocked the F out of me. Lol I'll check the 02
Old Mar 2, 2010 | 09:32 PM
  #22
If cyl 4 is dead and unplugging the O2 sensor doesn't help, then compression test the cylinders.
Also, is cyl 4 getting fuel?
Old Mar 3, 2010 | 07:32 PM
  #23
Well I'm getting fuel and spark and unpluged the 02 but it didn't change
I don't understand it but it only stumbles when it gets warm and below 3,000 rpm.
In 1st and 2nd gear most of the time.
Old Mar 3, 2010 | 07:34 PM
  #24
Is cyl 4 still dead?
Old Mar 4, 2010 | 03:59 AM
  #25
#4 Is getting fuel and spark I'll have to check compression
Old Mar 14, 2010 | 11:11 AM
  #26
So #1 165. #2 170. #3 150/145 #4 160/165
so obviously #3 is low
what is the compression spects and the vairation tolerance between cyl. ?????????
Old Mar 14, 2010 | 11:52 AM
  #27
Cyl 3 is a little low, but not awful. You would like to see no more than 10% variation from the cylinder with the highest compression. Did you do the compression test as described at the link in my signature. Does adding a teaspoon of oil to cylinder 3 raise the pressure?
Old Mar 14, 2010 | 08:17 PM
  #28
I didn't add the tea spoon but I will do so. I did notice a silver like chauky stuff on me radiator cap. Don't know if that means much but I do know it's not normal.
Old Mar 14, 2010 | 09:39 PM
  #29
Silver_Bullet_EK's Avatar
Default hesatation under load
replace the upstream o2 sensor, i had the same issue with mine, i replaced it, reset the CEL and it ran fine and have had no issues since
Old Mar 15, 2010 | 07:07 AM
  #30
I don't have a Cel on and when I check for codes nothing comes up.
Did yours not register the 02 sensor but u still replaced it ??? Thanks
