Civic LX Smokes after Head Reinstalled
Hi,
I had a head exchanged and when I bolted everything down to specs, it still made a lot of white (whater we think) smoke out of the back...more so than blowby. I took the head back off and realized I had left out the alignment pins. New gasket and alignment pins and it still did it.....smokes like crazy...runs good.
I pulled the head and had it pressure checked OK...and checked my cylinders for cracks. I had also pulled connection on each fuel injector and pulled the spark plg for that cylinder to see if the smoke decreased when cranking. Nothing definitive...but a little on cylinder 2.
The man at the head exchange place noted that there didn't seem to be much impression on the head from the gasket. I torqued to spec.
The question is...do I need new bolts for this...or is there maybe water in the bolt holes causing premature torque....or anything else you can think of before I go for round 3.
This is a 93 civic LX with the 1.5
Initial PSI was 135-160 before the rebuild...now around 190...still looks like too much smoke for blowby.
Thanks in advance for any help
Drax35
Feb 13, 2013 04:19 PM
LACivic95
Apr 17, 2009 08:09 PM
NR1236
Nov 18, 2005 01:28 PM
Robsonline
Apr 27, 2004 11:08 PM
