Civic Noise
Old May 23, 2005 | 08:30 PM
tshaunl's Avatar
Default Civic Noise
I am trying to figure out a noise that my 2001 civic is making. It is AT and 4 door. When I first start out in the morning I hear a thud sound after about 1000 ft from the front. Later, when I drive slow (less than 10 MPH), I hear a repeating thud sound from what I think is the rear wheel area, the sound resembles having a rock in the tire or running over a crack in the road. I can not see anything that looks unusual. In the front I do have a oil/grease looking smear directly behind the tire on the outside of the car. I do not see anything inside the wheel area though as I was thinking it was the CV Boot/Joint. The car only has 47000 miles on it. Any help would be great.
Old May 25, 2005 | 09:08 AM
DT Precision Tuning's Avatar
Default RE: Civic Noise
This noise is probably an unbalanced wheel, worn out wheel bearing, or misalignment, or egg shaped tire, many different things could be wrong with your tire/wheel. I suggest you take it to a garage to check it out if you cant figure this problem out yourself.
Old Jun 3, 2005 | 04:39 PM
powderdude's Avatar
I think i have the same sort of problem. Its in my rear right wheel and it veries with speed (niose slows down when I do and speeds up when accel) People have told me to check out the bushings? Havn't quite figured out where they are yet. I was going to try my wheel bearings first. Also it gets lowder with people in the back seat.
marcin69k
May 25, 2007 04:25 PM
malmsteen
Nov 8, 2005 12:20 PM
kerr_iss
Dec 27, 2004 09:48 AM
civicpsycho
Oct 10, 2004 06:18 PM
Squeek
May 22, 2004 12:32 AM
