civic periodicly stumbles
Old Nov 22, 2009 | 05:33 PM
  #31
Cryogenic SI's Avatar
Its kinda like that commercial where the car keeps getting abused. Yours is the real life version of the other half, the car abusing you.
Old Nov 28, 2009 | 05:51 PM
  #32
troutman's Avatar
Smile The latest...
Stumbled across this recall.http://www.tegger.com/hondafaq/tsb/civic/x02-031e.pdf
Hoping it's the problem.https://www.hondacivicforum.com/foru...d.php?p=621740
My civics vin is not on the recall list but,the symptoms are identical.It appears to be a fairly easy diy.New switch $37.00 to my door.At this point,I'm going for it...stay tuned.
Old Nov 29, 2009 | 01:17 AM
  #33
tmont2's Avatar
Default coil
I put a new coil in but had the same problem the next day. I saw the thread on the ignition recall, I'll try that next.
Old Nov 30, 2009 | 03:08 PM
  #34
coastierox's Avatar
I've got an '04 LX with a Man Trans that just runs ruff (misfires) whenever it rains. Sounds like a similar issue, except I am not getting a CEL when it happens. It kind of seems like water is splashing into the intake plenum and putting out a fire... Not so sure it would work like that...
Old Dec 1, 2009 | 03:58 AM
  #35
tmont2's Avatar
Default possible relay over heating
Does anyone know of a relay that may be overheating that would cause it not to start for 10-15 min after stopping......I replaced the main relay, that didn't work, tried the coil......?
Old Dec 1, 2009 | 05:05 AM
  #36
no but i do know that starter solnoids can cause problems like that, they start one min and next min not, inside the starter are brushes and they get build up and it causes bad connections, the blower motor for your air also does the same thing, i take them apart and wd-40 them and clean the contact points and put it back together.
Old Dec 1, 2009 | 04:59 PM
  #37
troutman's Avatar
Wink New starter switch
Got the new starter switch delivered today.Civic stalled twice on the way home as if it knew it's exorcist awaited it there.Installation was a piece of cake.Took it for a bit of a drive...no issues.We'll see what the next few days bring.Hopes are very high right now.Stay tuned.....
Old Dec 1, 2009 | 11:59 PM
  #38
tmont2's Avatar
The motor cranks but no fire......would that still be the solnoid....
Old Dec 17, 2009 | 05:34 PM
  #39
troutman's Avatar
Cool last call
Installed a new(used)ECM and after over one week of issue free driving,I think the problem is finally resolved.I have now personally installed or had installed,a new distributor,a new crank sensor (and timing belt,while we're in there) a new ignition switch and now a new(used)ECM for a grand total of around $450.Reasonable,no doubt in this day and age.
hutchhonda
Oct 11, 2013 06:06 AM
realdeal civic 00
Apr 18, 2012 08:46 PM
jkcinc
Jan 29, 2009 08:54 PM
03civex
Oct 24, 2008 08:30 AM
shanky1978
Apr 8, 2008 12:26 PM
