Civic Swap Question
Old Jan 6, 2011 | 08:21 PM
1.6LNVTEC's Avatar
Default Civic Swap Question
I have a 96 civic coupe dx 5 speed with the 1.6LNVTEC and i have a 1.6LVtec motor that i wanna put in and i was wondering what i needed to comeplete this swap????
Old Jan 6, 2011 | 11:09 PM
what year is the engine?
look here and post what the engine code says
Old Jan 9, 2011 | 06:55 PM
1.6LNVTEC's Avatar
Im pretty sure its the D16Z6 Vtec motor
Old Jan 9, 2011 | 07:00 PM
well the d16z6 is a obd1 motor and doesnt have a crank position sensor, it has a cam position sensor, the 96-00 civic engines( d16y5,d16y7,d16y8) is obd2 and has a crank position sensor. and the distributor plugs are different. so for the d16z6 to work in your car you will need to buy a p28 ecu (it comes from 92-95 civic ex/si) you will need to buy a obd2 to obd1 ecu jumper harness, and also a obd2 to obd1 distributor jumper harness
Old Jan 10, 2011 | 08:27 AM
1.6LNVTEC's Avatar
Ok ill make sure what the exact motor it is ill give you the code
rossimon13
May 30, 2012 06:20 AM
hydro_yang
Sep 12, 2009 01:18 PM
jakobe06
Nov 10, 2007 06:37 PM
Arkaydy
May 8, 2006 09:28 PM
outlaw2049
EK Swaps
Feb 2, 2006 10:03 AM
