Civic will not start on a hot sunny day ????
Old Jul 11, 2010 | 08:04 AM
mebedave's Avatar
Default Civic will not start on a hot sunny day ????
Hello…. Hope you can help me. I have a 93 civic 1.5L 5 spd. The problem I have has been going on for a few years now, and now seems to be getting worst (happens more often).
On a hot sunny day if I park the car in the direct sun light for a few hours the car will not start. It appears to be a fuel problem. I can start it right up with starter fluid and keep it running with the fluid but as soon as I stop it stalls. If I push the car into the shade for a few hours it will start right up like nothing was ever wrong. It’s driving me crazy I hope someone here might know what’s wrong. EFI is over my head too many wires and “do ma jigs” so if you have an idea for me to try please go slow.
THANKS!!!!!
Old Jul 11, 2010 | 09:00 AM
This is pretty much a textbook main relay failure. To confirm, turn the key to the ignition 2 position and listen for a low hum from the back seat. That'll be the fuel pump priming. If this does not occur, it is very likely that the solder on your main relay has cracked.
The relay itself is a grey box under the drivers side lower dash. It looks like this:
Pop it open and resolder the connections. Thats the cheapest and easiest fix.
Replacement is also an option but it's much more expensive.
Old Jul 11, 2010 | 11:31 AM
More details on resoldering can be found here:
http://techauto.awardspace.com/mainrelay.html
Old Jul 11, 2010 | 02:52 PM
mebedave's Avatar
Thank You guys so much your the BEST !!!!! This sound like my problem
Old Jul 13, 2010 | 02:45 AM
mebedave's Avatar
my resolder did not work. Car will not start at all now. I think the solder job looks real good,almost factory. I removed most all the old solder first. No big deal I'll just go buy a new one today. I'm just glad I now know whats causing it not to start on a hot day.
Old Jul 13, 2010 | 04:31 AM
Does the fuel pump prime?
Is there spark at all four plugs?
Any CEL codes?
Old Jul 15, 2010 | 01:17 AM
mebedave's Avatar
Installed new main relay and it runs like a top now.
Thanks for the help!!!
KingCole7
TV & Movie Review
Oct 2, 2011 03:58 AM
iHog
Jun 13, 2011 03:30 PM
arbab
Apr 21, 2011 09:15 PM
Icedoctor
Nov 14, 2007 01:18 PM
mr.w
Oct 9, 2006 03:27 PM
