Civic won't run after motor swap.
Old Sep 21, 2011 | 09:09 PM
4kaitlynmd's Avatar
Default Civic won't run after motor swap.
I recently did a motor swap on 2001 honda civic. I now have it completely finished but it fails to run on it owns. Actually sounds like it has a big cam on two cyls. I replaced the cap, plugs, rotor, and wires. However it will turn over briefly, then die. I was told it was a valve underneath the intake. Replaced it and im still stumped. Any ideas or answers would be great. Thank you.
Old Sep 22, 2011 | 05:07 AM
Check the timing belt timing. Check the firing order. Check the compression, are you sure the new motor is good? The USA model 2001 does not have a distributor, what motor did you swap to?
nonconsumerist1031
Jul 19, 2010 07:38 PM
cmlrc
Jan 18, 2010 07:15 AM
allisonmo2
Oct 5, 2008 10:54 AM
samilitant
Jan 8, 2007 10:47 PM
Remmy
Mar 6, 2005 01:18 PM
