clearing check engine light
The car reached 30K and the check engine light came on and now stays on. What needs to be done to clear the service code? Can I just go to AutoZone and get them to clear the code or is there a secret "press the gas pedal twice turn the car on and turn it off and then it's cleared?" I really don't want to disconnect the battery if I don't have to. I've heard that clears the fuel map memory. Any suggestions? Thanks
ORIGINAL: hoffa
and by the way you do not just want to clear it ,, you got to read it and diagnose why it came on in the first place
ORIGINAL: ventureman
With the car off. Hold in the reset button for odometer. While holding the button, turn car on, and wait about 20 seconds. light will clear.
Hope this helps
Chris
Hope this helps
Chris
