Clicking Noise
Old Jul 2, 2006 | 12:14 PM
1c1v1c1's Avatar
Default Clicking Noise
I have a clicking nouse coming from my passager front tire. When i turn the wheel one way it doesnt make the noise but if i turn it another way it does and i think it might have something to do with my axel...but i dont know..Any ideas?....
Old Jul 2, 2006 | 01:51 PM
Mad7s's Avatar
Default RE: Clicking Noise
axel bushings. If that's not what it's called it's because it's been a long week of sleeping on a hard wood floor. It's some rubber piece attached to the axel that's worn down. That's generally what causes that noise, especially if the vehicle has higher miles. I have the pleasure of enjoying your very same problem right now. It's not a major issue, but don't let it go on and on. Take it in and see what's up.
Old Jul 2, 2006 | 04:38 PM
weegaz22's Avatar
sounds like either the cv joints or a wheel bearing, got no idea what you guys call the cv joints in the states
Old Jul 2, 2006 | 10:48 PM
1c1v1c1's Avatar
alright well....how would you fix it..cuz most places cant raise my car on a lift cuz its too low...but could i fix it myself?.......
Old Jul 2, 2006 | 11:21 PM
AgentofDarkness's Avatar
I would say it is a CV joint, you can change it yourself. It sounds like the CV joint is gone so you will prolly have to replace the axle. It isn't too hard of a job, but it will require you to lift the car up. You don't need to get it up 6 feet in the air with a hydraulic lift, but you will need to get it on jack stands. Use the seach feature, i'm pretty sure i have a post that tells you how to change the axle but if you have any questions jus ask.
Old Jul 3, 2006 | 12:17 AM
nemethjames1's Avatar
axle is about 100 bucks... and if you can use a air gun it would help on getting the nut off... also your going to either have to take it from the ball joint or maybe the control arm bolts and swing it out of the way... and while your there make sure the axle seal does not leak! and try not to damage it.!! also get a pan and put it under the trans coz sometimes trans fluid will come out of there! my shop charges 175 parts and labor to fix, you might find a shop around your area that has a lift with low enough clearance, or is willing to do it on a jack and stands
Old Jul 3, 2006 | 12:26 AM
psychocivic's Avatar
thats why i love coil overs on my car. that way i can raise it if i ever need to take it to a shop for whatever reasons and they won't have a problem getting it up on the hydrolic lift.
Old Jul 3, 2006 | 06:38 AM
1c1v1c1's Avatar
thanks every1......Nemethjames1-where is your shop located?.......
malmsteen
Jun 9, 2023 09:52 PM
Talon585
21
Feb 6, 2006 12:00 AM
amg6975
14
Nov 3, 2005 08:16 PM
CT_554
Aug 9, 2005 05:04 AM
Squeek
May 22, 2004 12:32 AM
