CLUNK sound
Old Sep 24, 2011 | 10:52 AM
darren509's Avatar
Default CLUNK sound
Sitting in the car, and not driving at all, when I turn the steering wheel slightly back and forth it makes a CLUNK sound, so I replaced the inner and outer tie rods, mainly due to boots being ripped and 135,000 miles on the stock ones. So with the new parts on it still makes the noise. Could there be somthing inside the steering rack thats making this noise ? Considering the car is not even running just slightly turning wheel left to right ?
Old Sep 25, 2011 | 12:45 PM
The best way to check this is to have someone turn the wheel while you go around and listen to various parts to locate the source of the noise. Use a mechanics stethoscope or simply a length of hose held to your ear for pinpoint listening.
It could also be the u-joints and other parts in the steering column, inside the car.
Old Sep 26, 2011 | 08:11 AM
techtalk's Avatar
Darren,
Hmm, if I were to make an educated guess I am inclined to say that your lower ball joints may be worn. I've heard this issue occur to many Civic owners and most of them initially thought it was the tie rod ends. However, the real culprit turned out to be a worn lower ball joint. Inspect the lower ball joints and replace accordingly. For your reference, the OEM p/n is 51220-S04-003 and you'll have to buy two of them. They cost anywhere from $40-$55.
Good luck with the repairs!
Old Sep 26, 2011 | 10:44 AM
Paul79UF's Avatar
I had a similar problem on a Pontiac, it was a faulty front wheel bearing hub.
If the wheel bearings have never been replaced, that could be the problem.
carrera
Jul 15, 2013 06:28 PM
inthezoneac
Nov 16, 2009 12:59 PM
Act of God
Feb 18, 2009 10:05 PM
pendleton
Mar 19, 2006 03:32 PM
luk1993civic
Jul 30, 2005 01:05 AM
