95 civic losing coolant!
Old Sep 26, 2011 | 11:39 AM
joeyd16z6's Avatar
Default 95 civic losing coolant!
A couple of weeks ago i was driving on the highway when my upper radiator hose burst. I pulled off as soon as i could and left it sit in a parking lot for roughly 4 hours while i was at work. I bought a new hose and refilled the coolant and as i was driving home it started to overheat. Replaced the thermostat and radiator cap and now it has no overheating problems. However now it seems to be going through coolant fast. Like i filled it 2 weeks ago and it seems to be empty even the overflow. I looked in my exhaust to see what looks to be a little bit of water. not a pool of water but some drops.
Could this be a head gasket leak or a crack in the block?
It runs fine no problems with the oil just the coolant
Old Sep 26, 2011 | 12:25 PM
droopy128's Avatar
you probably didn't bleed it correctly when change out the hose.
idle your car, turn on heat in side the car, leave radiator cap off, run it till you see your fan kick on. Fill as needed during the process.
xkitex
Jul 11, 2012 05:27 AM
paak
14
Nov 19, 2011 02:24 PM
bulldog4life
Sep 24, 2011 03:21 PM
5009062
Sep 7, 2011 05:11 AM
kidintheshadows
Nov 27, 2007 10:15 AM
