Clutch Squeaky Noise?
Old Feb 11, 2009 | 11:36 AM
firecatf7333's Avatar
Default Clutch Squeaky Noise?
Whenever i push in my clutch i hear a squeaky noise. Clutch seems to work fine. should i grease it, and where do you grease? Just thinking for precautionary reasons.
Old Feb 11, 2009 | 11:52 AM
This type of squeaking sound can come from the clutch pedal and/or where the slave cylinder contacts the shift fork. Lubricate both.
Old Feb 11, 2009 | 12:15 PM
Default -
Where are those parts? how do i locate them
Old Feb 11, 2009 | 12:27 PM
Is the sound from inside the car, or under the hood?
If it's inside the car, try to grease the pivot at the top of the clutch pedal. It's very hard to reach without taking a considerable amount of stuff apart though.
Under the hood, the slave cylinder is on the front of the transmission near where the transmission meets the engine block. There is a rubber boot over it. Pull of the rubber boot and you will see where the piston rod touches a lever that goes toward the clutch inside. Apply a small amount of grease where the two parts meet.
Old Feb 11, 2009 | 12:32 PM
This diagram may also help:
Old Feb 11, 2009 | 03:52 PM
where is it in that diagram? Whats the bleeder screw have to do with anything
Old Feb 11, 2009 | 04:06 PM
For your enjoyment, I edited the diagram above for you. Grease the contact point between the slave cylinder and the shift fork.
Old Feb 11, 2009 | 05:18 PM
TheJGB3's Avatar
If you hear the squeak all the time while the pedal is held down it is the TOB (throwout bearing). If it is the bearing, then you might as well replace the clutch too since you have to pull the tranny anyway.
Old Feb 11, 2009 | 07:37 PM
I heard a sqeuky noise, but i'm not going to spend $500 to fix it.
Old Feb 12, 2009 | 10:00 AM
96Cex's Avatar
Mine has squeaked for years at the contact between the slave cylinder and shift fork. I greased it once with high temp grease and it stopped squeaking for about 1 month. I'm not willing to keep greasing it every month so I just let it squeak.
inthezoneac
Oct 16, 2008 08:30 PM
WhiteRabbit1021
Jul 15, 2007 09:33 PM
dooka4u4
Aug 4, 2006 08:05 AM
dooka4u4
Jul 18, 2006 02:51 PM
Spartan21
Oct 14, 2005 06:50 PM
