code 17
Old Feb 14, 2006 | 01:32 AM
smokingemcee's Avatar
Default code 17
My ECU throws code 17 often and it does not affect performance as far as I can tell. I think 17 is the VSS (vehicle speed sensor). My speedomoter, tachomoter, and odometor are all on hooked. Is that why I'm throwing the code? How do you hook those up? I have never done It but I'm sure it can't be that hard.
Old Feb 22, 2006 | 10:11 AM
Sphinx_1's Avatar
Default RE: code 17
Code 17 - VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
88-98 Civic
97-98 CRV
88-98 Prelude
94+ Integra
It depends where they are un-plugged at. at the engine or at your instrument cluster. Your odometer works off the speedometer. Not for sure about the tach. You should be able to get a flashlight and get down in the floorboard and look behind your instrument cluster and see if everything is plugged into it. If all is plugged in then look under the hood.
jdtrio
Mar 17, 2010 02:52 AM
ktownjeep
Jun 20, 2007 01:40 PM
Black Magician Hiro
Jan 15, 2005 08:47 PM
sneekapeek
Jun 28, 2004 09:31 PM
sirach38
Jun 19, 2004 10:35 PM
