Collapsed top radiator hose
Own a 1998 Civic LX with 120K miles - The top radiator hose keeps collapsing after I drive it and it cools down I find the hose is collapsed. When I open the radiator cap, the top hose springs to normal (there must be some kind of pressure or suction)
I replaced the radiator cap, cleaned out the overflow container and lines to ensure it wasn't blocked, replaced top radiator hose and bleed the air out of the radiator.
I doesn't over-heat, but concerned that something isn't working correctly
What else should I check?
Hose flat as a pancake LOL
Radiator is full of fluid and I turned the heat on HOT and full blast when I bleed system
(I bleed the cooling system by raising the front-end, took the rad. cap off, turned on engine, turn on heat full blast, let run for 5 minutes with cap off, then put rad. cap back on)
Thanks for the input
honda_farmboy
Jun 24, 2007 08:14 PM
