compression test fitting size?
Old Jan 27, 2012 | 07:12 AM
briceman124's Avatar
Default compression test fitting size?
hi what size compression test fitting do i use for a honda civic 1996?
14mm 16mm or 18mm?
Old Jan 27, 2012 | 02:18 PM
14mm 16mm or 18mm?
oh c'mon. no one knows? i've heard that you should use the 14mm size fitting. I know for a fact the spark plugs need a 16mm socket to get out. just seems odd you'd use a 14mm fitting when testing compression
Old Jan 27, 2012 | 02:33 PM
droopy128's Avatar
Use whatever size that fits into your spark plug hole, it hand tight and size is not based by your spark plug bolt size. Maybe I'm not clear of your intension.
Old Jan 28, 2012 | 05:18 AM
The spark plug holes have standard 14 mm threads, same as almost every other car. The fitting that came with the gauge should work with no adapter.
The hex drive on the plugs is 5/8 inch, which is almost exactly 16 mm but it is actually made to inch size. That has no relation to the size of the threads of course.
HONDASENCE76
Dec 15, 2007 10:39 AM
b8teen
17
Dec 19, 2006 06:17 PM
01CivicEX
Aug 30, 2006 11:05 AM
Meta
Aug 10, 2006 01:46 AM
chones2083
Jun 2, 2005 06:48 PM
