compression test help
Old Jan 9, 2008 | 01:10 PM
jcpower's Avatar
Default compression test help
hi i have a 1991 honda civic DX and i trying to do a compression test, one of the thing to do is take one of the wires from the distributor cap and conected to ground, witch one,there is two plug attach to the distributorcap and the 4 wire coming from the spark in to the distributor cap,any info will be apprecited, thank you for your reply.
Old Jan 9, 2008 | 08:26 PM
Default RE: compression test help
Go here for a DIY by Forty04:
https://www.hondacivicforum.com/m_386770/tm.htm
Old Jan 9, 2008 | 09:01 PM
imshirazy's Avatar
i personally just leave the distributor and make sure the plugs are nowhere near me or anything that the spark will damage
Old Jan 10, 2008 | 04:07 PM
jcpower's Avatar
In the Haynes book described that you need to disable the gas pump by taking the main relay out, also lock the throttle body wide open and take the primarycable from the center of the distributor cap and ground it, is this necessary to get an accurate reading
thank you
Old Jan 10, 2008 | 05:30 PM
JETSPEED333's Avatar
i usually just disconect the wiring to the distributor, take out all the spark plugs, and go from there
Old Jan 11, 2008 | 04:23 AM
ORIGINAL: jcpower
thank you
Just follow the DIY that was posted above
bronxbomerss2
Mar 20, 2012 12:36 PM
joshhondacivic
Jan 31, 2008 06:35 AM
natecivic92
Mar 13, 2007 07:41 AM
Meta
Aug 10, 2006 01:46 AM
chones2083
Jun 2, 2005 06:48 PM
