console
Old Sep 28, 2019 | 01:14 AM
johanz's Avatar
Default console
I have a '96 Civic with 5 speed manual that the speedometer and odometer is not working. The current instrument panel does not have tachometer on it. Most of the units I've found used have a tach on it. If I replace the entire instrument panel with one that has a tachometer will the tach work? Don't know if the electrical harness were same with ones with tach vs. ones without. Anybody can comment?
Thanks
Old Sep 28, 2019 | 05:46 AM
StifflersMom's Avatar
Cat Fuсker
it should work
Old Sep 28, 2019 | 03:17 PM
johanz's Avatar
Originally Posted by StifflersMom
it should work
So even though the temp gauge is moved from the left side display to the right side display the temp gauge function will work on the right display? I'm just wondering what affects on the electrical signal since the signal is now going to the opposite side of instrument cluster.
Old Sep 29, 2019 | 02:35 PM
Cat Fuсker
Shouldn't matter. It has nothing to do with where the gauge is.
Old Oct 17, 2019 | 03:59 PM
johanz's Avatar
Thanks for confirmation. Verified that they all use the same electrical harness. Swapped out with one with tach. Everything working fine!
93CIVICB20B
Apr 26, 2009 01:30 PM
nacivic
Apr 14, 2008 12:22 PM
97_Civic_LX_Matt
Dec 6, 2007 06:12 PM
sccatadriver
Sep 2, 2006 07:37 PM
xjbmx
Aug 19, 2005 06:32 PM
