Control Arm Problems
I'm Trying to replace My lower control arm bushing on my 2001 Honda civic EX. I cant seem to remove the control arm off. i removed the old bushing but now the The NEw One Wont Fit. AnY Pointer will Be Great Thanks.
hey bud the control arm bushing is pressed in a believe. the best way to do it is take the bushing put it over the hole and then take a block of wood, a rubber mallet and some wd40 and work it in. i did both of mine that way and it takes some time but works in the end.
When things are a "press in" fit like this, it is important to go straight in. If it's at any angle it will bind and not go in. Also if you've tried to force it in at an angle, that could have made a burr in the hole. File any burrs off (don't enlarge the hole though) and try again.
Stimpy
Mar 11, 2006 06:45 PM
ClayMayTion
Jan 7, 2006 10:35 PM
