Crank sensor plug, how to unclip it?
Old Mar 1, 2006 | 05:10 PM
ToddK's Avatar
Default Crank sensor plug, how to unclip it?
Hi, this is my first Civic and I don't know much about it. But I do know the wire to this plug has been cut by a belt and I need to unclip this plug to free the wire to do the repair (and clip the wire in place to keep from happening again) Here is a picture of my plug http://www.classicglastron.com/plug.jpg It's under the fuel injector rail close to the timing belt end of the motor. To release the plug do I have to push or pull something? I'm going to have to get someone with a small hand to reach in there to do it and I want to know ahead of time what instructions to give. Many thanks in advance your your help.
Todd
'97 Civic LX
Old Mar 1, 2006 | 05:14 PM
baker's Avatar
Default RE: Crank sensor plug, how to unclip it?
should be able to push that and pull the plug away.
Old Mar 1, 2006 | 05:16 PM
ToddK's Avatar
At the bottom right of the picture is that tab with the steps. I push (not pull) that?
Thanks,
Todd
Old Mar 1, 2006 | 06:05 PM
baker's Avatar
i think so. if pushing doesn't work, try pulling haha... i can't remember things unless my hands are actually on them.
Old Mar 1, 2006 | 06:28 PM
AgentofDarkness's Avatar
Be carefull when you pull on those plugs, i've broken a couple because i did too much pulled on the tab too much and didn't take the connector out fast enough.
zerojett
Oct 18, 2011 03:01 PM
therobesons
Oct 6, 2008 11:47 AM
Mario89
Nov 27, 2006 09:31 PM
MarkyG
Oct 9, 2006 11:03 PM
joshr799
Mar 22, 2006 08:53 PM
