Crazy Electrical Madness, Need Help!
Old Aug 2, 2007 | 05:36 PM
neojedi78's Avatar
Default RE: Crazy Electrical Madness, Need Help!
WELL, i left this forum alone for awhile and I should go ahead and finish and say, IT WAS A GROUND!!!!! The rear of the chassis has a main ground, it was bad, plus my external coil fried a couple wires... replaced those and all is well. As for the code 16, that is probably the injector I pulled out, it had bent connector, and a black screen filter.. Oh yeah, if you ever have fuel spray out through the throttle body, check your O rings on the injectors.... dont pis off the honda gods.. ill repost another discussion on the injectors...
Old Aug 6, 2007 | 05:40 PM
neojedi78's Avatar
No More code 16, replaced bad injector and that did it, and you don't have to reset the ecu, atleast I didn't need to.
Rab16
Jun 8, 2009 05:51 PM
jousai7
Dec 29, 2008 05:32 PM
xgrafcorex
Sep 21, 2007 03:26 PM
acdosher
May 18, 2007 07:22 PM
aquessada
Feb 5, 2005 12:35 PM
