cruise control
Old Apr 8, 2008 | 09:29 AM
bafpc1's Avatar
Default cruise control
Daughters 1996 civics cruise control works intermittingly.speedometer also drops to zero for a few seconds. Any tips
Old Apr 8, 2008 | 09:36 AM
Default RE: cruise control
Sounds like a faulty vehicle speed sensor (VSS), which sits atop the transmission. (search forum for pictures)
Is the Check Engine Light (CEL) ON?
Start by inspecting the VSS connector. It may be loose or corroded. If the connector and wiring look fine, the VSS may need to be replaced.
Old Apr 8, 2008 | 09:44 AM
bafpc1's Avatar
yes the cel has been on for awhile is this tied in with the cruise. thanks for the quick response
Old Apr 8, 2008 | 09:46 AM
Here's how to pull the CEL code from the ECU at home:
http://www.honda-tech.com/zerothread/1901557
I suspect the code will indicate a problem with the VSS/VSS circuit. The VSS is essential because it tells the cruise control system how fast the car is going.
Old Apr 10, 2008 | 08:39 AM
boostd92's Avatar
my civic (96 ex)does the same thing with the cruise, i can set it, it will hold that speed for a second, then start dropping, now i have no CEL, so could it be a vacuum leak somewhere, isnt the cruise ran off vacuum?
dmsteele92831
Jul 23, 2007 11:10 AM
Cappelle
Apr 21, 2005 01:30 PM
civicracer_44
Feb 3, 2005 07:04 PM
civic9988
Oct 24, 2004 07:22 PM
frameb
Jun 14, 2004 11:28 PM
