cv & rack & pinion boot
Old Apr 1, 2008 | 05:45 PM
islandguy's Avatar
Default cv & rack & pinion boot
Hey I need some advice. Both boots, drivers side cv and rack & pinion boots are torn. I know I need to replace both asap....but money is tight right now and I can only do one at the moment. What one should I do first? Or should I just FIND the money and do both. I'm assuming it'll be easier to do them both at one time. When I replaced the passenger side cv we just traded it in for a rebuilt one. My brother in law did the work so I'll save on the labor. Can you get a rebuilt r & p as well?
Thanks
J
Old Apr 2, 2008 | 08:04 AM
JimBlake's Avatar
Default RE: cv & rack & pinion boot
For the CV boot...
Little more money but lots less work to replace the entire axle assembly. Check prices & take your choice.
For the steering rack it's the opposite situation.
It's way cheaper to replace just the boot. AND it's way less work to replace just the boot.
But thatassumes the boot hasn't been open long enough for dirt to enter & damage the insides of the rack.
Old Apr 3, 2008 | 05:19 AM
islandguy's Avatar
Being that the car is 13 years old do you think I should just go ahead and replace the rack & pinion?
Old Apr 11, 2008 | 08:24 PM
fglaustin's Avatar
no
Old Apr 14, 2008 | 12:17 PM
bpcorliss's Avatar
You should be able to get a CV joint boot service kit. It is a PITA to do, but it is WAY cheaper than replacing the drive shaft. If your joints are not "clicking" you may be able to replace the boot with no issues.
I would start there. Though, your rack may be toast soon if you don't replace those boots. If you don't replace the CV boots, there is a good chance that the CV joints could seize. If that happens, you run the risk of busting the drive shaft. That is messy and will leave you stranded no matter where you are. Plus, if you break a drive shaft, your "Park" gear won't work and your car will just roll down hill no matter where you are.
On a scale of 1-10 for severity, broken CV joint would be 8. For the loss of power rack is 5.
VX_LSvtec
Feb 4, 2007 10:25 PM
nelpasa
Nov 13, 2005 03:24 PM
nelpasa
Oct 31, 2005 01:07 PM
AgentofDarkness
May 27, 2005 10:35 PM
AgentofDarkness
May 25, 2005 12:20 PM
