D16y7 distributer on d16y8
Old Jan 17, 2007 | 10:05 AM
Jayman018's Avatar
Default D16y7 distributer on d16y8
I am doing a mini me head swap on my 98 honda civic dx. I was just wondering if i could use the distributer from my original engine y7on the y8 head.
Old Jan 17, 2007 | 10:46 AM
Fiasco's Avatar
Default RE: D16y7 distributer on d16y8
sorry, wrong thread
Old Jan 17, 2007 | 01:04 PM
pimpciv98's Avatar
I'm pretty sure they are the same. At least the service manual does not differentiate between the 2. Timing is the same also. 12 degrees +- 2 degrees BTDC during idling/neutral.
Old Jan 17, 2007 | 03:35 PM
Jayman018's Avatar
Thank man, but if someone knows anything else about the two if there different let me know.
Old Jan 17, 2007 | 08:02 PM
ogrmazzocco's Avatar
there is not diference... you can use your distribuitor since you are using your same harnes..unless you planing to use a obd0 instead yours...
Old Jan 18, 2007 | 12:14 AM
custompainter's Avatar
i'm using the y7 dist. on my y8 right now the car runs so it will work
but there are other issues to follow with the ecu if you plan on using the vtec
i'm trying to figure it out right now
Old Dec 21, 2021 | 03:44 PM
Victor bel's Avatar
[QUOTE = Jayman018; 317758] Estoy haciendo un mini cambio de cabeza en mi 98 honda civic dx. Me preguntaba si podrķa usar el distribuidor de mi motor original y7 en el cabezal y8. [/ QUOTE]
JCCC
Mar 29, 2007 12:15 PM
Krazy
Feb 7, 2007 03:50 PM
kman92civicsi
Dec 1, 2006 08:36 PM
farfrumugen
Aug 11, 2005 10:55 PM
kngflp
Aug 27, 2004 12:04 AM
