D16Y8 Miss Fire
hey guys i have a cylinder 1 missfire code. i have changed plugs, wires, cap, rotor. tested injectors. tested compression and these where my readings.
cyl#1=105
cyl#2=150
cyl#3=60
cyl#4=190
i am feeling like its the head that needs to be changes. could timing be an issue that would cause this? any help is appreciated.
cyl#1=105
cyl#2=150
cyl#3=60
cyl#4=190
There is definitely a problem there. That's a major difference in compression across all 4 cylinders. Do a leakdown test. If the compression numbers improve, that tells us it's probably in the block. If there's no change, it could indicate the problem is in the head, maybe with the valves.
Edit.... There is a trick to getting the bolt out, had to remove dust shield on bottom or tranny and wedge a screwdriver into the flywheel then took a breaker bar with a 4 foot cheater bar and 3 people lol, i dont think that was OEM torque specs on that bolt.
I changed timing belt today, and car is still having issues, we checked and double checked the timing, and it still has a hesitation when you take off from a dead stop, it sputters sometimes when accelerating in 1st gear, and when you sitting at idle its down to like 500rpm.... Someone please help!!!!!
Last edited by JWilli97EKlx; Nov 1, 2012 at 05:46 PM. Reason: added new information
Red_Devil
Jun 16, 2012 09:38 AM
crimsonnblue
Dec 10, 2006 09:02 PM
accelerate, accelerating, blue, car, d16y8, fires, hesitation, idle, make, miss, misses, smoke, sputters, white, whitish
