D16Z6 Timing Help???
Old Oct 4, 2006 | 04:58 PM
CrazyJames's Avatar
Default D16Z6 Timing Help???
I'm trying to set the timing on a 94 honda civic ex all factory. I'm having trouble setting it exact, and I'm about Half a tooth off. Is this alright??? I usually drive an hour each way at 85mph <3100rpm>. If I'm half a tooth off then I should set it at half a tooth retarded for top end ??? Any thoughts??????????
Old Oct 4, 2006 | 07:26 PM
HARI.'s Avatar
Default RE: D16Z6 Timing Help???
did you jump the connector when you were trying to set the timing?
Old Oct 5, 2006 | 12:30 PM
CrazyJames's Avatar
no i did not jump the connector.
Old Oct 5, 2006 | 08:52 PM
b8teen's Avatar
jump the connector before you time, and pull off when ur done. if u dont do that, the ecu will compensate for the timing you set it to.
smackpower
Jan 13, 2024 01:42 AM
dbrine
Nov 8, 2011 09:17 PM
ChasingAdrenaline
May 27, 2010 07:25 PM
V8DIET
Dec 29, 2008 06:07 AM
fast93civic
Dec 17, 2004 03:06 PM
