D17a2 swap to d17a1 not going past 4000 rpms??
Old Aug 7, 2019 | 05:25 AM
Codyo's Avatar
Default D17a2 swap to d17a1 not going past 4000 rpms??
Can someone help I just swapped an 03 civic ex d17a2 manual to a d17a1 motor and it won’t go past 4000 rpm I’ve read that it’s cause of the vtec but can I just buy a non vtec ecu and plug it in get the key flashed and get rid of the problem??
Old Aug 9, 2019 | 06:50 AM
drakon543's Avatar
that sounds like a feasible solution. if your current ecu is trying to advance into vtech and its just not present it might be holding you back. on an 03 i dont think the key thing will be an issue. i dont think the keys were ecu programmed until later i think it should be a plug and play.
Old Sep 9, 2020 | 12:19 PM
FluePinger!'s Avatar
Did you get any further with this swap? This is the exact same swap that I’m looking to do. Trying to figure out what it’s going to take to complete it correctly. I also hear the exhaust is different?
civicguy2488
Jan 22, 2011 06:27 PM
falkirkfc5
May 26, 2008 01:15 AM
museboy07
Apr 28, 2008 02:42 AM
Tonymore
Feb 22, 2007 03:05 PM
FlipHKD720
Oct 13, 2006 09:43 PM
