Dash lights quit working
Old May 9, 2009 | 05:27 PM
jchc413's Avatar
Default Dash lights quit working
Since I got the car (97 civic lx) I had to move the dial to get the dash lights to come on. Tonight they wouldnt come on at all. Havent noticed anything else not working. Im thinking either loose connection or bulb? Any other suggestions?
I might try and add leds if Im going to have to take it apart anyway...
Old May 9, 2009 | 05:31 PM
gwl's Avatar
gwl
BAD Dimmer switch? Common problem.
Old May 9, 2009 | 06:19 PM
jchc413's Avatar
cool, I was hoping there was some sort of "common problem." Pretty easy fix?
Old May 9, 2009 | 07:27 PM
I agree with gwl, the dimmer switch is a very common problem. But first check whether fuse 30 is blown. Next carefully pry the dimmer switch out of the dash, and then install a jumper wire into the connector such that the red and black wires are connected. The dash lights should now illuminate at full intensity with the key turned to ON(II). If so, replace the dimmer switch.
Old May 9, 2009 | 08:49 PM
if your dimmer switch turns out to be bad, i have a mint condition one for sale for $10 plus shipping.
I also have a faded one (color is faded on the grey plastic cover) for $5 plus shipping.
Old May 10, 2009 | 06:49 AM
jchc413's Avatar
Yep I already saw it in your for sale thread. Once I get my daughter down for a nap Ill go check the fuse and switch and PM you if I need it.
wearelove
14
Oct 11, 2012 08:56 AM
subnet76
Nov 5, 2011 10:04 PM
Tranqz
Jul 9, 2009 04:52 AM
av3rag3am3rican
Oct 6, 2007 08:33 PM
sincitycivic
Feb 21, 2007 12:01 AM
