Dead battery... Alternator going bad????
Old Sep 14, 2006 | 06:28 PM
Crazed's Avatar
Default RE: Dead battery... Alternator going bad????
Thanks for all the replies. I put in a new battery and it seems to be doing fine. I still want to figure out what happened though. The battery I had hooked up was one of those expensive yellowtop optima batteries. So I am guessing there must be a short somewhere with my aftermarket speakers. I will try hooking up a VOM meter fglaustin and see if I can figure out anything with that.
Old Sep 14, 2006 | 11:23 PM
cyberx32's Avatar
How old was the battery? they usually need to be replaced every one or two years.
Old Sep 15, 2006 | 12:31 AM
deserthonda's Avatar
ORIGINAL: cyberx32
wow ,, where do you get your batteries at ?? at a junk yard ??
battery should last at least 3 full years
Old Sep 15, 2006 | 10:20 AM
AgentofDarkness's Avatar
ORIGINAL: fglaustin
read where that was not recommended anymore.
with the car running, connect voltmeter to the battery.
should read something like 12.8 to 13 (something).
With the engine running the battery voltage should be around 13.5-15V. If the voltage is under 13 volts while the engine is running them your alternator is not charging the battery. If your speaker system had a short you would be blowing fuses and melting wires. The problem might be that the amp is wired wrong and is drawing current all the time.
Old Sep 15, 2006 | 11:26 AM
fglaustin's Avatar
bout right - the 5 year batteries that i buy will usually go for bout 4.
and i am one of the very few that only uses distilled water in the battery.
harder to find the distilled water - guess the ladies of this day and age do not use an iron
danstelter
Sep 15, 2013 09:23 AM
Peg_Leg
XBox/XBox 360
May 7, 2010 06:42 PM
TheCivicLx
Jul 18, 2009 05:27 PM
AnimalWild
Jun 27, 2008 11:46 AM
