del sol ecu/ rpm problems d series zc
Old Aug 15, 2009 | 09:21 PM
93delsols's Avatar
Question del sol ecu/ rpm problems d series zc
i just recently got a 93' del sol s type with a d series zc eninge 5 spd s20 tranny and i got a couple problems i never ran into before until now.
my 1st problem is my engine light is on constantly it doesnt flash or anything could it be a bad ECU?
my other question is when i press on the gas my rpms peak at 2000 at a stop and a go my rpm's don't go past 2000 and it sucks.there is a sensor on the other side of the throttle body that connects to the throttle with a spring in it. could that cause it?
any info would help
Old Aug 15, 2009 | 10:03 PM
Did you pull the CEL Codes?
Old Aug 15, 2009 | 10:05 PM
93delsols's Avatar
not yet i have to w8 til my scanner gets fixed
Old Aug 15, 2009 | 10:45 PM
scanner??? its obd1 you dont need a scanner
we have a how to check cel
there is a grey clip with a brown and green wire use like a wire or paper clip and touch them togethere and turn your key to the on position it will flash a certain amount of times that is your code..
read this....
http://www.honda-tech.com/showthread.php?t=1901557
Old Aug 16, 2009 | 07:06 AM
Due to an error in your ECU, the system has gone into limp/backup function mode. Try to pull CEL codes from the ECU.
livejamie
Aug 12, 2011 06:53 AM
bfodle
Jul 20, 2011 09:57 AM
Faramire
Aug 1, 2010 11:42 AM
bingis
May 22, 2004 12:56 AM
sol2k
May 4, 2004 09:41 PM
