dizzy problems...
Old May 27, 2007 | 07:40 PM
94zcivic's Avatar
Default dizzy problems...
my car runs fine....but when i cruise my car starts to skip and kinda bogs a bit....but as soon as i lay on the accel....it'll pick up and go. i'm thinkin it could be the dizzy but the guy who helped with the wiring said it could be the alternater, but i had it checked and it tested good. any ideas of what the problem could be?
Old May 27, 2007 | 08:14 PM
GReddy_Civic's Avatar
Snail'n Admin
Default RE: dizzy problems...
I had this problem. Seems like I have a lot of these problems. My problem was that when I was just idling, my car would bog down a lot, close to shutting off. When I would get on the gas, it would be delayed and would feel as if something was holding the engine back. Turns out that it was a sparkplug wire or a sparkplug since i replaced both. I don't know when you had anything replaced, but you can start with cheaper things like wires, plugs, distributor cap and rotor. If that doesn't fix it, you may have a slightly more expensive problem.
ohbiskits
Sep 29, 2005 02:56 PM
AnakinKenobe
Jul 5, 2005 11:00 AM
AnakinKenobe
May 6, 2005 09:32 AM
