double clutching
Old Nov 28, 2007 | 01:10 PM
  #21
jakeolas's Avatar
Default RE: double clutching
Gah gah gah gah gah
All these terms and my head is spinning.
match-rev, what is match reving
Old Nov 29, 2007 | 09:22 AM
  #22
timmytim's Avatar
ORIGINAL: Impreza WRX
vvrrrrOOOOORREEE! (6k RPM) VMMmmm! ... ...(5k RPM) ... ... ....(4k RPM) .....(3500 RPM) VOOOOOOOORRRRRRRREEEE! VMMmmm! ... ... ... vrrr.....
^^Match-Revving, ahahah [sm=gears.gif]
Old Nov 29, 2007 | 11:52 AM
  #23
LuV2SkRaTcH's Avatar
Hmmm, double-shifting seems correct from what most people are saying, but does relate to power shifting... clutch in, shift to neutral, clutch out, clutch in, shift to a gear
But I thought power shifting was when you downshift to raise up your rpm's and increase your torque to pass or after a turn (maybe more likely while drifting). I think this would be useful if you are about to pass a guy on a track, and turning on a track, and drifting. What I do when I do this, is when I'm shifting out of the gear, I keep my foot on the gas long enough so that the rpms increase a little bit then shift to the next gear.
Clutch in, shift to neutral, clutch out, blip (rev to match next gear's rpms) gas, clutch in, shift down to a gear, clutch out.
And I haven't heard of speedshifting, but that could be the technique that implies not releasing the gas during shifts...
Forty04
Nov 12, 2010 03:51 PM
TheMoogly
Nov 8, 2006 09:18 AM
tinyy
Jul 14, 2006 08:07 AM
mormilesthanu
Jan 3, 2005 07:27 PM
2000Si
Sep 20, 2004 10:08 PM
