draining and filling manual transmisson fluid
Old Jul 22, 2005 | 03:19 PM
REGNARTS_'s Avatar
Default draining and filling manual transmisson fluid
I have a 95 Civic Ex, manual trans and was wondering how to drain the transmisson fluid and change it. I read my manual but it didn't say anything about changing the fluid. Is it that hard? Because I called jiffylube and they told me, the price is about $99. I was like man, it can't be that hard. Any tips would be appreciated.
Old Jul 22, 2005 | 03:30 PM
GSRDevil's Avatar
Default RE: draining and filling manual transmisson fluid
$99.00[sm=noooo.gif]
I'm in the wrong line of work obviously.
Old Jul 22, 2005 | 03:40 PM
REGNARTS_'s Avatar
so how do you change it?....
Old Jul 22, 2005 | 03:50 PM
GSRDevil's Avatar
It's real easy, easier than changing your motor oil. You'll want to pick up one of those funnels with the long hose on it, two quarts of Honda MTF, (or synchromesh or 10W30 if you are in a bind but Honda MTF is preferred) and a oil drain pan. Just remove the bottom bolt and drain. Replace the bottom bolt remove the one about halfway up the tranny and insert the hose end of the funnel. Run the funnel up to the top of the engine compartment and dump in the MTF. It's full when you can dip your little finger in and feel the oil level with the bottom of the fill hole. Replace the filler bolt. VOILA!
I'm going to look around and see if anyone has any pictures hosted I can bandwith "borrow" of the D tranny
Old Jul 22, 2005 | 03:59 PM
GSRDevil's Avatar
no love for the Devil on that pic yet...
If I recall correctly, the drain plug is a round head bolt with a 3/8th square drive. You just use a regular 3/8ths ratchet on it. I can't remember but I think the filler is either the same or a 17mm
Old Jul 22, 2005 | 04:06 PM
REGNARTS_'s Avatar
yeah, pictures would be nice too... and thanks.
Old Jul 22, 2005 | 04:13 PM
97CivicEX's Avatar
I think it was 10W40 weight oil for the manual as replacement for the honda mtf.
Old Jul 22, 2005 | 04:19 PM
REGNARTS_'s Avatar
ORIGINAL: 97CivicEX
I thought that was what I read in manual. Where can i get the honda MLT? I'm guessing only at dealers?
Old Jul 22, 2005 | 04:45 PM
GSRDevil's Avatar
Ahhh the Manual transmission fluid debate! [8D]
The owners manual for a Civic recommends Honda MTF but also states 10W30 can be used.
An Integras owners manual recommends to only use motor oil if MTF is not availiable and to refill with MTF a.s.a.p.
A lot of Honda drivers swear by the feel that GM Syncromesh gives them. I happen to be one of them and nothing bad has happened to my tranny yetknock wood. If you have a few extra dollars you might want to experiment with this for yourself. See if you like the shift feel synchromesh gives.
To be absolutely safe though, Genuine Honda MTF isn't going to do you wrong .
thatguywithahonda
Apr 13, 2012 06:46 AM
turbo10
Sep 13, 2010 03:23 PM
brown_wallstreet
Apr 14, 2008 05:34 PM
00IntegraLS
Jan 19, 2008 08:11 AM
honda joshua
Jan 12, 2006 10:42 AM
