e-brake
It seems when i go to use my e-brake i have to pull it excessivly far to be able to slide. If i give it a slight/moderate pull it will just slow me down. Im replacing my front and rear brakes tomorrow will this help? Is this normal or do i have to do some work?
john
john
well id say lift the rear end off the ground alittle bit then spin 1 wheel... see how much it drags...... THEN pull the ebrake afew clicks and spin the tire again.... if it has a drag id say its fine..... but if it spins the same simply pull the center console trim off and tighten down the rear bolt/nut along the cable and it will tighten up the ebrake cable. just be SURE that the wheel doesnt drag with it completly off... otherwise youll probably warp your drums/ wear your pads out and just DRAG @SS around town.LMFAO
but i think for MOST civics at least the ones ive driven ALWAYS had to have the Ebrake handle just about ALL the way up to lock the wheels to make them slide on dry ground . just remember its JUST A EBRAKE.... dont use it to do all your stoping or even half of it... will cause alot of wear plus not as safe.
Save the bootlegger turns for video games. If the e-brake can make the wheels lock up even though the handle may be nearly all the way up, it is working properly.
If the car has drum brakes on the rear, a common reason for the e-brake to become loose is that one of the self-adjusters is not working. This also reduces the performance of the regular foot brake.
ORIGINAL: FlipHKD720
if you've used it alot for ebraking you may need the cable tightened/replaced. I know i do after last winter.....haha
driving down a icy road with the rear brakes locked up with my @ss swinging back and forth freaking out the guy behind me.... PRICELESS hahahahhha
Ed Fisher
Aug 20, 2009 11:47 AM
Cosworth
Dec 15, 2008 05:35 AM
burgernuds
18
Aug 16, 2008 07:20 PM
j2performance
Jan 15, 2008 01:48 PM
