ecu codes 132 and 137
my 2001 with over 200 thousand miles honda civic Lx engine 1.7. i got the codes 132 and 137 i know the 132 is
P0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage
and code 137 is
P0137 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit Low Voltage
i have changed both oxygen sensors, and cleaned the connectors, the connectors was oil soak from an oil leak but i used alchol and cleaned both them
now within 10 miles i got the code P0131 could the oil on the connectors caused this and maby i didnt get them cleaned?
and code 137 is
