ECU trouble codes (CEL)
Old Jun 27, 2005 | 11:59 PM
Street Sniper's Avatar
Default ECU trouble codes (CEL)
OK, 4 blinks and then 3 quick blinks. Is that trouble code 43?
Edit: I am assuming it's 43, "Fuel supply system." What could I have done to get this trouble code by installing my header? Anyone else get this code after a header install?
Initially I forgot to use the crush gasket between the header collector and the cat so there was a massive exhaust leak. I assumed that the leak was causing me to run lean and consequently get a CEL. Does this seem feasable or do ya'll reckon it's omething else?
Old Jun 28, 2005 | 08:13 PM
Default RE: ECU trouble codes (CEL)
Ok, I reset the ECU and it's holding steady (no CEL). How many engine cycles does it take to spit a code back at you?
Old Jun 28, 2005 | 08:37 PM
sacicons's Avatar
until the mistake repeats itself. if it does it right away, then it will give you the code right away. if not, then it might not be a problem anymore.
crimsonnblue
Jul 18, 2006 11:41 AM
Naudlee
Jun 8, 2006 09:02 PM
stevenmgrr
Sep 30, 2005 09:01 PM
stevenmgrr
Sep 30, 2005 08:21 PM
Amanda
Mar 10, 2005 12:12 PM
