The EF wont start :(
Old Jul 13, 2008 | 07:13 PM
Old Skool EF's Avatar
Default The EF wont start :(
Whats up guys? a couple of buddys Of mine and I put a new trans in my EF and after we were all done and hooked everything back up we went to start the bitch it wouldnt start. you can hear the starter but theres nothing. we let the batter charge for a lil bit and we still didnt have enything. so the we check the grounds and they all looked fine. the ground that goes from the Valve cover to the front of the car started to smoke. imstumped b.c it started b4 we swaped trannys. Thanks -Phil
Old Jul 13, 2008 | 07:45 PM
Default RE: The EF wont start :(
i'm not sure if it would cause that to happen, but do you have the ground from the tranny to the frame hooked up?
Old Jul 13, 2008 | 07:50 PM
On later models, there are grounds on the thermostat housing and the transmission. Carefully double check those grounds.
Are you saying that the starter is not cranking the engine or that the starter is cranking but not the engine is not firing up? If the latter is true, do you have spark and is the fuel pump priming?
Old Jul 13, 2008 | 07:55 PM
The big wire from battery (-) to the frame and then on to the transmission is not working. The starter current is trying to pass thru the little wire on the valve cover, which should not happen.
Old Jul 13, 2008 | 09:58 PM
jpnolan's Avatar
If a wire is smoking you need larger gauge wire replace the wire and you might have it running.
Old Jul 14, 2008 | 09:00 PM
Whats up Guys? thanks for all the help. i looked at all the grounds. Im starting to think that my starter is bad. im goin to take it out and take it in to get tested 2marro. hopefully thats what it is. Thanks - Phil
Old Jul 17, 2008 | 07:07 PM
Shes Back. i had to get a new starter. The old one was shoot. Takin it to the Track 2marro night to see if theres a Difference between that old LS tranny and my new B-16 Trans. thanks guys for all the help.
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
niteryder
Dec 29, 2004 06:47 PM
AndyI
Oct 6, 2004 09:36 AM
89 pos
Jun 25, 2004 05:35 PM
