Electrical nightmare!!!!
Old Dec 11, 2009 | 10:07 PM
ADNOHJ>UR FACE's Avatar
Default Electrical nightmare!!!!
ok so i just got my honda. i fixed everything i could so that i could drive in comfortably. So i go to drive it and it drives fine. But it turned dark on me real quick and i turned the lights on.. well the interior lights wont come on at all. Nothing that is alluminated when you turn ur lights on comes on inside the car. Ok. So i checked all the fuses and they are all good. so then i thought maybe its the dimmer? changed it to a new one and still doesnt work. so now im starting to think its some wire not connected or something. but i really dont see how it would be that since those two wire that are red are hooked up to everything that lights up when you turn ur lights on. Basically saying they are all hooked up in parallel. Someone please help me out.
Old Dec 11, 2009 | 10:21 PM
Largen's Avatar
Check the connections behind your gauge cluster? other then that, you might end up having to go wire by wire with a test light to see where the path of power is disrupted... And with your dimmer that you replaced, did you purchase a new one? or get a used one? if you got a used one, i would check it out with a multi-meter just to rule it out.
Great thing about electrical, if you have an issue your almost always able to locate exactly what it is.
Good hunting.
Old Dec 12, 2009 | 05:29 AM
Make sure the tail lights on the outside of the car work. The dash lights get power from the same switch and fuse as the tail lights. The dimmer is often the problem so like the other guy said be sure you have a good one.
Next would be to pull the cluster and check the bulbs. It is possible for every single bulb to be burnt out.
Old Dec 12, 2009 | 06:22 AM
supersize's Avatar
Sir Banned-a-lot
my cluster lights AND my gear lights (automatic) dont light up either haha
lilgreencivic
Oct 30, 2008 08:27 AM
Cousens
Feb 26, 2006 04:57 PM
nightrider46
Sep 21, 2005 04:43 PM
StifflersMom
Jul 19, 2005 08:52 PM
deadcivic
Mar 9, 2005 09:25 AM
