Electrical Problems...
Old Mar 5, 2009 | 12:57 PM
CamisPurple97Dx's Avatar
Default Electrical Problems...
Ok so
I have a 1997 Honda Dx. Just bought it. Drove it all the way to Richmond (from Suffolk) and it drove there fine. Drove it around half the day... and it dies... Starts off a jump, but as soon as we took the cables off it died.
Took the battery in to NAPA. They said it was fine. Definately needed a charge but none of the cells were bad. Charged it. Then we took the alternator in ... tested it... passed putting out like 13.9 volts.
put it all back together and drove it home... later it did the same thing...
realized that as it was dieing all the lights and whatnot began to flicker... if i reved the engine that would stay steady, as soon as the RPMs drop it starts wanting to cut out again...
Finally got it home...
Cant figure out what the problem is... The battery checks out, the Alt. checks out , the serpentine belt i think is fine.... it just doesnt make any sense...
( I drove it 100 miles before it died again) is it running on just the battery and then dying???
I dont get it
PM me with some suggestions... My fiance is taking the Alt. off as we speak... going to have it tested again.... ill be back on later to see any respnses left!
Thanks in Advance
Cami
Old Mar 5, 2009 | 01:11 PM
Is fuse 15 under the dash blown?
Is the CEL ON?
Is the dash charge/battery light ON?
Click the fuse 15 link in my signature.
Old Mar 5, 2009 | 03:09 PM
Yes this sounds like the fuse 15 problem. You need to test if the alternator is putting out while it is on the car, by testing the battery voltage with the engine running. If the wiring is damaged, the car won't power up the alternator. So even though the alternator itself is OK, it won't charge when installed.
fierychick
Jan 29, 2009 11:23 AM
drewbhot
Feb 20, 2006 04:13 PM
RSXt3
Nov 5, 2005 01:55 PM
abe_frohman
Sep 17, 2005 08:05 AM
lihin
Jun 30, 2005 05:29 PM
