Engine Bogging
Old Oct 19, 2008 | 03:23 PM
99civicExCoupe's Avatar
What if i just buy a new IACV/EAVC will that fix the problem? and where would i run the coolant lines to since i was auto before?
Old Oct 19, 2008 | 03:40 PM
You may also need to change the wire harness as the MT IACV has a 2P connector and the AT IACV has a 3P connector.
Old Oct 19, 2008 | 03:45 PM
well what if i just dont do anything and leave the light will it end up hurting anything in the long run?
Old Oct 19, 2008 | 04:19 PM
Not a good idea. The IACV is very important. The engine won't idle properly and may have additional problems, and you also won't pass inspection in many states.
Old Oct 19, 2008 | 09:54 PM
gwl's Avatar
gwl
Yeah, it won't be good ideal. I see you live in Redlands, CA. They will check for the CEL during the smog check. Also, your gas mileage might suffer with a CEL.
You can go to the dealer to find out how to route the coolant hoses. Have them print out the a part diagram for a manual trans, I had them to this when I was replacing all my hoses.
Old Oct 21, 2008 | 08:47 AM
so i've been reading other peoples problems similar to this on other forums and something that might make sence... could this be a vacuum leak? and would'nt that cause it to idle weird causing the IACV CEL to come up?
Old Oct 21, 2008 | 08:51 AM
A vacuum leak would cause a high idle, which I don't think you have.
Old Oct 21, 2008 | 08:54 AM
no but when the car is cold there is no problem and when it fully gets warm this is when it happens.. then it will idle low at a stop but it will go higher then lower ranging from maybe 500 to 1300rpm. would this still be and IACV?
Old Oct 21, 2008 | 09:49 AM
Like Ron said, a vacuum leak tends to make it too high all the time. Do you have a steady idle with the wire unplugged at the EACV? If the engine stalls under that condition, turn up the air screw on the throttle body until it just barely runs (400-500 rpm).
Old Oct 21, 2008 | 09:58 AM
So if the engine stalls turn up the screw while the EACV is unpluged? and how come it only does it when its fully warmed up?
