Engine Bogging problem
Old Feb 11, 2012 | 01:19 PM
Dean.'s Avatar
Question Engine Bogging problem
Hey guys, very new here, but i wanted to see if anyone could help me with my problem (Bare with me as the details are leading to my problem are somewhat specific.):
I own a 1992 Honda Civic LX, 1.5L 16 Valve and over time the car sputters on me simultaneously at VERY low speeds. When up to operating temperature and at idle: Stalling occurs intermittently at red lights, stop signs, and when i accelerate heavily after red lights. No CEL's on dash after stalling, Oil and Battery light stay on. When gas is below 1/4, it stutters alot, above half and it works decently. Ive changed spark plugs, Will change oil when the weather in BC decides to stop being rainy, cleaned throttle body, Changed air filter (Stock), tranny Oil has not been changed, timing belt has not been changed, NGK spark plug wires.
Any suggestions?
Old Feb 12, 2012 | 02:37 PM
droopy128's Avatar
fuel filter??
Old Feb 13, 2012 | 10:46 PM
Turtlegrip's Avatar
get a new fuel filter and clean the idle air control valve (dirt [lol] cheap). then unplug the battery for 15 minutes, then run the car for about 25 mins then drive around a little. I would hope that fixes it >_>
Old Feb 14, 2012 | 12:47 AM
Dean.'s Avatar
Thank you guys for insight on the situation, I will clean the iacv and replace the fuel filter and let you guys know the results shortly after.
Old Jan 18, 2013 | 07:48 AM
dawnwest's Avatar
Did this fix your problem with the stalling?
Old Jan 21, 2013 | 05:07 PM
Fuel filter tends to make the engine starve for gas at high rpm, not at idle. My guess is that it was the IACV.
Old Feb 11, 2013 | 09:36 PM
Dee Sleezy's Avatar
I am having the same issue with my 92 civic d15 b7 it is fine in first I cleaned up the spark plugs it worked for a little bit but once I stopped it started bogging down in second and now it bogs down in first oil is tranny is fine not showing anything on the dash but the oil light when it dies , should I check out the mass air flow ? Or go with what was suggested on this forum ? Let me know please it's my only car and its quite a setback ! Thanks
Old Feb 14, 2013 | 07:30 AM
Those2Cars's Avatar
Get a new O2 sensor, it might not be throwing a light for it, but it sounds like a typical o2 sensor poblem
Im Vibin
Jul 22, 2013 10:32 PM
jewellworks
19
May 8, 2011 06:23 AM
Garon
15
Oct 6, 2007 03:10 PM
Workman
May 24, 2007 05:55 AM
DamageINC
May 15, 2007 04:56 PM
