Engine Burning lots of oil
Old Mar 24, 2008 | 08:49 PM
Hailchristian's Avatar
Default RE: Engine Burning lots of oil
definitly burning oil
Old Mar 25, 2008 | 07:08 PM
Alright....finally got a compression test
results are as follows
Dry
1 160
2 160
3 160
4 160
Wet
1 170
2 160
3 160
4 170
Old Mar 26, 2008 | 08:04 AM
so...what do my compression results point to...? ? ? ¿
Old Mar 29, 2008 | 01:06 PM
definitly the head gasket.
Old Mar 29, 2008 | 01:20 PM
As you were burning oil and probably coolant, did you have two problems, a bad head gasket and bad valve seals?
Old Mar 29, 2008 | 01:21 PM
ORIGINAL: RonJ
bad pcv valve..the oil burning was gone after i replaced that...
Old Mar 29, 2008 | 01:24 PM
Thanks. Just trying to learn from your experience. That must have been a major head gasket failure to affect all four cylinders.
Old Mar 29, 2008 | 02:01 PM
ORIGINAL: RonJ
uh...well...yeah..epic fail!..i only think it was effecting the middle 2..those are the ones that had off compression test
and i guess the engine could have been burning a little oil from the head gasket too..cause there was definitly oil in the water and water was in the cylinders..
Old Mar 29, 2008 | 02:45 PM
ORIGINAL: Hailchristian
ORIGINAL: RonJ
I assumed all four cylinders had low compression as they were all 160 dry, whereas I thought they should be about 180. Wouldn't the wet test only measure leaking from piston rings?
Old Mar 29, 2008 | 07:48 PM
well..i figure if it could get oil into the cylinders just as easy from a bad head gasket as it could from bad ring seals.....either way oil was getting into the cylinders.
