engine dies going down the road???
Old Dec 16, 2005 | 10:17 PM
tx90crx's Avatar
Default engine dies going down the road???
I have a 1990 crx completely stock with just 110,000 miles, while going down the road it dies for just a second like you turn the key off then right back on, any ideas would be helpfull.
Old Dec 16, 2005 | 10:40 PM
patcheway's Avatar
Default RE: engine dies going down the road???
i have a 1989 crx si and mine did the same thing it would only stay running if you had the key turned like you were trying to start it it was the ignition switch
Old Dec 17, 2005 | 03:38 AM
nasty97ex's Avatar
another person had a similar problem and it ended up being his coil, might want to check that out
Old Dec 18, 2005 | 03:21 PM
Mr.Striker's Avatar
i would check the ignition swich like he said. either that or something else electrical.
Old Dec 18, 2005 | 04:19 PM
neon3kgt's Avatar
mabie cap n rotor.
Old Dec 18, 2005 | 05:42 PM
cmasonrun's Avatar
i doubt its the cap and rotor, i had to replace that and that wasnt any symptons
Old Dec 19, 2005 | 09:24 AM
MR2nCivic's Avatar
when you say its like the key way turned off do you lose your guages, lights raidio, ect. ect. if so in my experiance it would more often be ither the ignition switch or some thing in one of the many ground wires
Old Dec 19, 2005 | 09:28 AM
pirata's Avatar
CHECK YOUR GROUNDS, IT SOUNDS LIKE SOMETHING IS NOT MAKING CONTACT WHILE ITS RUNNING.
Old Dec 22, 2005 | 09:52 AM
leco516's Avatar
have a garage run a diagnostic otherwise
your'e just chasing your tail trying to figure
it out, to many variables
1stHonda
Mar 23, 2021 12:07 AM
drewrussell2011
May 17, 2014 07:57 PM
queenlowla
Jul 31, 2013 06:18 PM
jcodysmith
May 1, 2010 07:11 AM
morepower
Apr 5, 2009 04:51 PM
