Engine overheating problems
Old Jul 10, 2007 | 03:04 PM
nevrgonastopme00's Avatar
Default Engine overheating problems
Hello, a few months back I bought a '95 Civic DX (1.6L 4door) and just recently (few weeks) I have been seeing some weird cooling issues. It runs just under the halfway mark of the gauge, just the second I hit 60mph it slowly climbs up until I turn the heater on full blast, I have not let it go extremely high, but I don;t know where the top limit is, with the heater on it steadies at about 3/4 of the gauge. Any ideas of the weak point of my cooling system that is causing this so I can at least have a starting point?
-Kris
Old Jul 10, 2007 | 04:16 PM
ic892003's Avatar
Default RE: Engine overheating problems
i have a similar problem, but for some reason when i go over 75 mph, for over 15 min the needle starts to go up, havent tried anything, but good luck with u, hope u find the resolution
Old Jul 10, 2007 | 04:19 PM
ic892003's Avatar
the cheapest thing u can do is replace the thermostat
Old Jul 10, 2007 | 04:22 PM
Yeah, I thought it might be the thermostat, either that or the radiator itself, I just would like to take it apart with a good idea in mind as to what it is.
-Kris
Old Jul 10, 2007 | 06:54 PM
gwl's Avatar
gwl
My temp would creep up on the freeway and it was the thermostat.
Old Jul 11, 2007 | 01:23 AM
jim9418's Avatar
If your gauge creeps up slowly and turning on the heater helps, you may just have a worn water pump. A new thermostat may improve the symptom initially. The blades/impellars (spell?) of the water pump will erode over time. If the car has ever had dirty rusty looking coolant or only mostly water in it for a long time the pump will go bad. If you are anywhere near time for a timing belt change, do the water pump too.
Old Jul 11, 2007 | 02:56 AM
ic892003's Avatar
ORIGINAL: gwl
has it been working fine since u changed the thermostat and how long ago was this?
Old Jul 12, 2007 | 04:08 PM
Hmm, it didn't look like there were any contaminants when I was messing around the first time, so I will try the thermostat first and see if I see any problems anywhere else. Im still open to suggestions and ideas since I have not done too much with cooling systems in cars.
-Kris
Old Jul 12, 2007 | 08:33 PM
gwl's Avatar
gwl
ORIGINAL: ic892003
ORIGINAL: gwl
It was last summer, I noticed my temp was creeping up on the freeway. I turned on the heater to get the temperature down until I replaced the thermostat. Also, when I replaced the stat, I wentahead and changed out all the coolant hoses. I think there were around 10 hoses that took a couple hours to do.
Old Jul 15, 2007 | 11:22 AM
acertaindrug's Avatar
did changing all the coolant hoses help at all? i have a similiar issue and have already replaced therm and water pump.
timmaytoyota
Sep 29, 2011 01:45 PM
Michael97Civic
21
Jun 20, 2010 05:55 AM
StevieG1223
Jul 2, 2007 04:47 PM
trebor_2005
May 19, 2006 01:40 AM
Physikz
Apr 3, 2006 03:44 PM
