Engine studdering at low rpms
Old Dec 23, 2005 | 02:45 AM
ten2doyle102's Avatar
Default Engine studdering at low rpms
so yeah, i got a 95 civic ex and i had some problems in the past with my ignition system. i had a Crane Cams Ignition system in the car and for some reason something fried on it and i had to have the stock ignition reinstalled. I also have a high pressure fuel rail on it as well as a CAI. Now that i have the stock ignition my car when you try to get it to go from like a stoplight or something it will studder for awhile and then between 3000-4000 rpm it will rev normally. I am guessing that it is probably from the fuel rail putting more gas into the car then the stock ignition can handle temporarly flooding the car. its the only thing that i can think of and i was wondering if i am way off on that. Also, how much horsepower would i lose from the stock ingition?
Old Dec 23, 2005 | 03:16 AM
Default RE: Engine studdering at low rpms
also i forgot to ask, i want to boost it eventually, but i dont want to spend $3000 on it. Is an electric supercharger worht my time? they only put like 2.1-3 lbs of pressure and i was wondering if that even worth my time. hell i dont even think i could fit it in my car with the CAI installed. I was just wondering what everyones opinion was?
Old Dec 23, 2005 | 03:26 PM
MR2nCivic's Avatar
it sounds like you are pritty close in your diagnosis after market ignition systems are designed to handel more fule, a factory ig nition system if you ave too much fule will cuase the engine to stumble at low rpms (fluding its self out) once you get to higher rpm the car requiers more fule so the shuttering will go away. to check if it is fluding pull your plugs if there is like a black residue on the end or if they are wet and the smell of gas is strong then it most lickly is geting way to much fuel
Old Dec 23, 2005 | 04:51 PM
yeah thats what i figured since it never did that with my aftermarket ignition, thanks!
08civiclx
Mar 23, 2008 07:26 PM
sickcivic07
Feb 16, 2006 04:51 PM
civicexracer
Nov 13, 2005 12:53 PM
brokenjaw
Oct 14, 2005 02:56 PM
civicexracer
Oct 4, 2005 07:53 PM
