Engine turned off from overheating
Old Jun 30, 2013 | 04:38 AM
fragzzone's Avatar
Default Engine turned off from overheating
Hello, I have a noob question for Civic experts...
My 98 Honda Civic EX was overheating but before I could stop to let it cool off and check the radiator the engine shut down while driving. I pulled to the side of the road and after a few minutes I turned the key and the car turned on.
Does the vehicle have some sort of protection system to prevent it from burning out???
After cooling checking the radiator I found it is cracked from the top and need a replacement.
Thanks in advance for your reply!
Old Jun 30, 2013 | 06:16 AM
Does the car still start each time? if it is, then don't bother worrying about it.
Old Jun 30, 2013 | 06:56 AM
fragzzone's Avatar
It does, the radiator fan does not though. I guess that will go back to normal when I manage to get the radiator fixed.
Thanks!
Old Jun 30, 2013 | 07:35 AM
There isn't a protection system. They allow it to run until the engine possibly burns out, because having a car shut down on the freeway strictly to protect the engine could be dangerous to the people inside.
Old Jun 30, 2013 | 07:00 PM
You can test the fan if you would like. Google it and it will show you how. Jumping the fan connector located on the thermostat housing.
If you are replacing the radiator because it was old, it might be a good idea to replace your thermostat and hoses, too.
deviantCivic
Jan 28, 2008 03:30 PM
99CivOnRotas
Dec 3, 2007 07:11 PM
glomgold
Aug 18, 2007 11:50 AM
duce110
Jul 12, 2007 07:04 AM
