Faulty brake bulb ! Please help
Old Oct 13, 2006 | 01:19 AM
txedomask433's Avatar
Default Faulty brake bulb ! Please help
So I have a 2005 Civic EX. One of the brake lights went out, so I changed the bulb and it still doesn't light up. I asked someone if it could be the fuses but he said that both lights would have gone out if it was a fuse. Any ideas guys ?
Old Oct 13, 2006 | 02:39 PM
AgentofDarkness's Avatar
Default RE: Faulty brake bulb ! Please help
Are both brake lights and the brake light in the windshield out? If just one brake light will not work after replacing the bulb, i would check the wiring to the bulb. It is also worth checking to see if you have power to the connector that hooks up to the bulb.
Old Oct 14, 2006 | 12:06 PM
patcheway's Avatar
try another bulb
Old Oct 16, 2006 | 09:24 AM
anyone else have ideas. can i just go to the local auto store and buy some fuses ? If it is the wiring, what do i do ?
Old Oct 16, 2006 | 09:44 PM
luisynayan's Avatar
Had the same problem once. Bulb was good, no fuses were blown. Had the wiring checked, and it turned out it was disconnected. Had it spliced and rewired, problem solved.
dfx4343
Feb 15, 2010 06:15 AM
denisholden
Aug 12, 2007 09:31 AM
dudes96
Apr 28, 2007 11:48 AM
chrisspliff
Oct 22, 2006 07:53 PM
dj_ipirate
Dec 19, 2005 07:14 AM
