fixing streched throttle cable.
Old Jan 19, 2012 | 07:44 AM
briceman124's Avatar
Default fixing streched throttle cable.
so i think my throttle cable maybe stretched and i've read a little online about how to fix it. they say that the cable should have only about 1/2 an inch of play. does this mean that you should be able to press down on the cable for about 1/2 an inch at which point the throttle should begin to open?
Old Jan 19, 2012 | 09:02 AM
droopy128's Avatar
It meant pressing the gas pedal and adjustment screw on top of intake.
Old Jan 19, 2012 | 03:18 PM
Start by having someone floor the gas pedal (engine NOT running) while you check that the throttle lever moves all the way to wide open. If it does, no adjustment is necessary.
To adjust, move the two nuts that hold the stationary part of the cable to the bracket near the throttle body.
Old Jan 20, 2012 | 06:04 AM
thank you, i will try that.
n8te81
12
Mar 4, 2008 02:26 PM
xsdudztx
Aug 9, 2007 07:45 PM
littledog
Jul 23, 2006 08:06 PM
hockeyc574
Jun 22, 2005 10:20 PM
spevie
Mar 1, 2005 06:48 AM
