Front disc brakes dragging
Old Oct 18, 2017 | 08:36 AM
Tazdevil0055's Avatar
Default Front disc brakes dragging
I have a 91 honda civic.the guy I got the car from informed me that the calibers.MC.brake booster.rubber brake lines had all been replaced.i bleed the system numerous times.but after driving and using brakes for about 4 miles the the front disc brakes begin to drag.after jacking up the front end I realize that both of the calibers are stuck to the point where I have to extremely apply pressure to rotate the tires.but after I open the bleed screw the tires free up.the thing that puzzles me is when I bleed the brakes. I get a steady stream of fluid but while there stuck no fluid comes out of the bleeder..please help
Old Oct 24, 2017 | 04:21 PM
Duane4238's Avatar
I'd say even though he says he replaced the brake hoses, I'd do it again. Old or cheap hoses will collapse internally and hold pressure against the caliper. When you open the bleeder, the pressure is released. I had this problem on my corvette. The rear calipers locked up so hard I couldn't drive home. Cheap and easy fix. Check with a real mechanic if you don't think this will take care of the problem. Good luck.
Duane
Old Oct 25, 2017 | 01:56 PM
udraft's Avatar
Caliper pins (or whatever they're called). They're probably dry and dirty. Get them off, clean, check for "true", lube and re-install. Also the contact points (wings) on the pads should have some brake grease.
jprommel
Apr 28, 2008 04:38 AM
ErikElvis
Dec 8, 2007 09:44 PM
snosurfa7
Jun 12, 2007 09:31 PM
snosurfa7
Jun 9, 2007 01:18 PM
mcoulter
Oct 18, 2006 11:24 AM
